15.4 IDMP CLI
idmp-cli is the official command-line tool for TDengine IDMP. It is designed for local terminal workflows, scripted automation, and agent-driven operations. The CLI combines configuration management, authentication, OpenAPI command discovery, and explicit safety controls in one entry point, so operators can query, troubleshoot, and perform controlled write actions without relying on the Web UI.
If the goal is to let an LLM connect to IDMP directly through remote MCP, see 15.2 MCP Interface. If the goal is to run stable, auditable IDMP commands from a terminal, CI pipeline, or agent runtime, idmp-cli is the better fit.
- Install
idmp-cli. - Run
idmp-cli config initto save the server URL and complete the first login. - Run
idmp-cli auth check --remoteto confirm the server accepts the current credential. - Use
idmp-cli schema search <keyword>before running a command, and always use--dry-runbefore write operations.
15.4.1 When to Use IDMP CLI
idmp-cli is a good fit for the following cases:
- Daily terminal-based IDMP queries and troubleshooting, such as inspecting elements, analyses, panels, and authentication state.
- Scripted, CI, or batch API execution with explicit risk acknowledgement for non-readonly operations.
- Claude Code or other agent workflows that need discoverable, reusable, and auditable IDMP commands.
- Situations where the exact command path is not known in advance and must be located through schema inspection.
15.4.2 Prerequisites
Prepare the following items before starting:
| Item | Description |
| IDMP server URL | Use the real endpoint that your environment can reach. The examples below use https://<IDMP_HOST>:6034. For certificate or network troubleshooting, switch temporarily to http://<IDMP_HOST>:6042. |
| Credential | Use a pre-issued API key. |
| Local dependency | The minimum requirement for both online and offline CLI installation is Node.js 16+ and npm. Prefer a currently supported Node.js LTS release when possible. |
| Supported platforms | The CLI supports macOS, Linux, and Windows on x64 and arm64. |
| Optional agent runtime | If the CLI will be used with Claude Code or another agent, install the related plugin or skills later in the process. |
If you must switch temporarily to http://<IDMP_HOST>:6042 for connectivity checks, do so only inside a trusted, isolated network and avoid sending API keys or other sensitive credentials over HTTP.
On an interactive terminal, config init can prompt for missing secrets. The examples in this page prefer stdin so they can be copied into scripts and automation flows directly.
In the examples below, <IDMP_HOST> and $IDMP_API_KEY are placeholders. Replace them with real values before running the commands, or set the environment variables first.
Linux / macOS
export IDMP_API_KEY='api_<key_id>.<secret>'
Windows PowerShell
$env:IDMP_API_KEY = 'api_<key_id>.<secret>'
15.4.3 Installing IDMP CLI
Install the CLI first. Claude Code plugins and third-party agent skills are add-ons and should be installed only after the CLI itself works correctly.
15.4.3.1 Online Installation
Install the published npm package globally:
npm install -g @tdengine/idmp-cli
Then verify that the command is available:
idmp-cli --help
idmp-cli --version
This step installs the CLI only. It does not install the Claude Code plugin or any other agent skills.
15.4.3.2 Offline Installation
If the environment cannot reach npm directly, use the extracted release bundle instead. Run the installer from the root of the extracted offline bundle:
Linux / macOS
bash installers/install-cli-offline.sh
Windows
installers\install-cli-offline.cmd
install-cli-offline.* installs the launcher package plus the matching platform binary package, and validates Node.js / npm availability and package version consistency before changing the global npm state.
15.4.4 Creating a Profile and Logging In
A profile is a saved environment configuration. For most first-time users, starting with the default profile is enough. config init can create or update that profile, authenticate immediately, and persist the session locally.
15.4.4.1 Log In with an API Key
Linux / macOS
printf '%s\n' "$IDMP_API_KEY" | idmp-cli config init \
--profile default \
--server https://<IDMP_HOST>:6034 \
--api-key-stdin
Windows PowerShell
$env:IDMP_API_KEY | idmp-cli config init `
--profile default `
--server https://<IDMP_HOST>:6034 `
--api-key-stdin
The CLI records the session as api_key authentication, which works well for long-running scripts and agent workflows.
This command does 4 things in one step:
- Saves the
defaultprofile. - Stores the target server URL.
- Authenticates with the API key.
- Persists the session for later commands.
15.4.4.2 Verify the Current State
After the first login, run the following checks immediately:
idmp-cli profile list
idmp-cli doctor --offline
These commands confirm the saved environments, verify that the server accepts the current credential, and check whether local configuration, session storage, and generated metadata are all in place.
These examples use IDMP's default external HTTPS port 6034. When certificate or network troubleshooting is required, switch only the protocol and port temporarily to http://<IDMP_HOST>:6042, but only for short-lived troubleshooting inside a trusted, isolated network. Avoid sending API keys or other sensitive credentials over HTTP, and move back to HTTPS after the issue is resolved.
If the environment uses a self-signed certificate, idmp-cli does not skip certificate verification by default. HTTPS works only when that certificate, or the CA that issued it, has already been imported into the current machine's system trust store. If the trust chain is not in place yet, use http://<IDMP_HOST>:6042 only as a temporary troubleshooting path, and avoid sending sensitive credentials over HTTP. The CLI does not currently provide a --insecure-style flag to bypass certificate verification.
15.4.5 Using IDMP CLI with Agents
idmp-cli works on its own, but it also serves as an execution backend for agent workflows. The recommended order is to install the CLI and initialize a profile first, and then add the plugin or skills that match the target runtime.
15.4.5.1 Claude Code
For local Claude Code, the recommended installation path is the TDengine idmp-plugin. The plugin already bundles the matching skills, so the same skills should not be installed into Claude Code a second time.
Online installation
claude plugin marketplace add taosdata/agent-skills
claude plugin install idmp-plugin@taosdata
Offline installation
From the root of the extracted offline bundle:
Linux / macOS
bash installers/install-plugin-offline.sh
Windows
installers\install-plugin-offline.cmd
By default, the plugin is installed into ~/.claude/plugins/idmp-plugin. To load that directory explicitly, run:
Linux / macOS
claude --plugin-dir "$HOME/.claude/plugins/idmp-plugin"
Windows PowerShell
claude --plugin-dir "$env:USERPROFILE\.claude\plugins\idmp-plugin"
15.4.5.2 Other Agents
For agents other than Claude Code, install taosdata/agent-skills separately when the runtime supports a skills directory or an equivalent mechanism. One important detail is that install-skills-offline.* still defaults to Claude's skills directory: ~/.claude/skills, or %USERPROFILE%\.claude\skills on Windows. For non-Claude agents, do not rely on the default target.
Online installation
If you want to inspect which skills are available in the repository first, preview them with:
npx --yes skills add taosdata/agent-skills -g -y --list
Then install the skills:
From the root of the extracted offline bundle, pass the target agent's skills directory explicitly so the installer does not keep writing into Claude's default location:
Linux / macOS
bash installers/install-skills-offline.sh --target-dir /path/to/other-agent/skills
Windows
installers\install-skills-offline.cmd --target-dir C:\path\to\other-agent\skills
If --target-dir is omitted, the script copies the skills into Claude's default directory and does not infer which other agent should receive them. The offline installer is only a directory copier; whether another agent can discover those skills still depends on that agent's own directory convention or import flow.
If the target agent does not provide a dedicated skills directory, copy assets/skills/* from the offline bundle into that agent's skill location, or import each skill's Markdown content into the agent's reusable prompt or instruction system manually. In every case, make sure idmp-cli is already installed and available on PATH.
15.4.5.3 Recommended Agent Workflow
The following execution order works well for most agent tasks:
- Let the skill classify the task first: element, RT analysis, panel, data import/export, permissions, and so on.
- Use
idmp-cli schema search <keyword>to locate the real command path. - For unfamiliar commands, inspect
idmp-cli schema <service.resource.method>before execution. - Prefer shortcut commands when they fit; switch to structured commands when more precision is needed; use raw API calls only as the final fallback.
- For write operations, run
--dry-runfirst and execute the real command only after the preview looks correct. - After a write, reread the target object or run
auth check --remote/doctorwhen connection state must be confirmed.
15.4.6 Understanding the Command Model
idmp-cli is easiest to learn when its command model is treated as 4 layers.
| Type | Structure | Best use | Example |
| Built-in commands | idmp-cli auth ... | Configuration, login, profile switching, troubleshooting | idmp-cli auth check --remote |
| Shortcut commands | idmp-cli element +list | High-frequency read operations with simpler arguments | idmp-cli panel +search meter --size 10 |
| Structured commands | idmp-cli <service> <resource> <method> | Precise control of the OpenAPI-derived command path and parameters | idmp-cli element elements list --params '{"current":1,"size":20}' |
| Raw API command | idmp-cli api GET /api/v1/... | Cases where the exact path is already known, or the surface is not exposed as a top-level command | idmp-cli api GET /api/v1/elements --params '{"current":1,"size":20}' |
When the exact command path is uncertain, start with schema search. That is more reliable than guessing, and it works especially well in agent-driven flows.
15.4.6.1 What +list Actually Means
Commands such as +list, +search, and +get are shortcut subcommands attached to one service command group. The leading + is part of the command name itself. It is not shell syntax and not an original IDMP API path. The CLI registers these shortcuts under the related service, such as element +list, analysis +list <element-id>, and panel +search <keyword>.
A shortcut still resolves to one real schema path before execution. For example:
| Shortcut command | Actual mapping |
idmp-cli element +list | element.elements.list |
idmp-cli element +search <keyword> | element.elements.search |
idmp-cli analysis +list <element-id> | analysis.analyses.list |
Because of that, the same shortcut name can mean slightly different things under different services. element +list means “list elements”, while analysis +list <element-id> means “list analyses for one element”. What they share is the design goal of a high-frequency shortcut layer, not one universal argument template.
If the final target is unclear, the safest way to inspect a shortcut is to use --dry-run first:
idmp-cli element +list --parent-id 100 --dry-run
idmp-cli analysis +list <ELEMENT_ID> --dry-run
The preview prints fields such as shortcut, method, path, params, and risk, so you can see which structured command the shortcut resolves to. At execution time, shortcuts still pass through the same validation, safety acknowledgement, auto paging, and output formatting pipeline.
15.4.7 Recommended Daily Workflow
Use the sequence “find the path → inspect the schema → run a readonly command → preview writes” as the default working pattern.
15.4.7.1 Find the Right Command Path First
idmp-cli schema search elements
idmp-cli schema element.elements.list
idmp-cli element elements list --help
schema search finds candidate paths from a keyword. schema <service.resource.method> shows parameters, risk classification, paging support, and example commands. For unfamiliar commands, inspect the schema first and execute the real call second.
15.4.7.2 Prefer Shortcut Commands for Common Reads
idmp-cli element +search <keyword> --size 20 --format table
idmp-cli element +list --size 20 --format table
idmp-cli analysis +list <ELEMENT_ID> --format pretty
idmp-cli panel +search meter --size 10 --format table
Shortcut commands are a good fit for common read scenarios such as searching for elements, listing elements, or reviewing analyses for one element. Under the hood they still call generated commands, but the interface is easier to remember for routine operator work. For commands that need an ELEMENT_ID, locate the target ID first with element +search or element +list.
15.4.7.3 Use Structured Commands for Precise Control
idmp-cli element elements list --params '{"current":1,"size":20}' --format table
idmp-cli analysis analyses list --params '{"elementId":"<ELEMENT_ID>","current":1,"size":20}' --format pretty
Structured commands map directly to the OpenAPI service, resource, and method model. They are the right choice when the service / resource / method relationship must be explicit or when the schema output is part of the execution workflow.
15.4.7.4 Use Raw API Calls as the Fallback Layer
Use the raw api command when the endpoint path is already known or when the target surface exists only as a proxy path. Even then, it is still best to check whether a shortcut or structured command already provides a more stable abstraction first.
15.4.7.5 Use Auto Paging When the Result Set Is Large
idmp-cli element +list --size 100 --page-all --page-limit 500 --page-delay 200ms --format table
idmp-cli api GET /api/v1/elements --params '{"current":1,"size":100}' --page-all --page-limit 500
--page-all is only for GET commands that use current / size style pagination. When enabled, the CLI fetches page by page and merges the result set. Use --page-limit to cap the merged row count; 0 means unlimited. Use --page-delay to add a pause between page requests when the backend should not be hit too aggressively.
If the server does not clearly indicate that pagination has finished, the CLI aborts auto paging after 500 pages. In scripts, CI, and agent workflows, it is safer to pair --page-all with --page-limit instead of collecting pages without a bound.
15.4.8 Safe Write Execution
idmp-cli enables explicit risk acknowledgement for non-readonly operations by default. This matters even more in scripts, CI jobs, and agent-driven workflows.
15.4.8.1 Preview the Request First
idmp-cli schema analysis.analyses.create
idmp-cli analysis analyses create \
--params '<PARAMS_JSON_FROM_SCHEMA>' \
--data '<DATA_JSON_FROM_SCHEMA>' \
--dry-run
--dry-run prints a request preview instead of performing the write. The preview usually includes method, path, risk, params, and data, which makes it the safest way to confirm the request shape before execution. Required fields vary by method, so use schema to inspect the current parameter and request-body structure before composing the real payload.
15.4.8.2 Execute the Write Deliberately
--ack-risk
If --ack-risk is omitted on a non-readonly command, the CLI refuses to execute the operation. On interactive terminals, some write actions may also ask for an explicit confirmation. The safest default is always “--dry-run first, --ack-risk second”.
15.4.9 Local Storage and Environment Variables
The following local paths and environment variables are especially useful in scripts and agent integrations:
| Item | Default or variable | Purpose |
| Config directory | ~/.idmp-cli | Default location for CLI configuration and session metadata. |
| Config file | ~/.idmp-cli/config.json | Stores profiles and the current default environment. |
| Sessions file | ~/.idmp-cli/sessions.json | Stores session metadata for each profile. |
| Current profile | --profile or IDMP_PROFILE | Switch the active environment temporarily. |
| Server URL | IDMP_BASE_URL | Point the CLI to a server directly without loading a local profile first. |
| API key | IDMP_API_KEY | Supply an API key through the environment. |
| Config directory override | IDMP_CLI_CONFIG_DIR | Redirect config and session storage to a custom directory. |
| Session storage mode | IDMP_CLI_SESSION_STORAGE | Choose file, keyring, or auto storage mode. |
On Windows, these default paths usually map to %USERPROFILE%\.idmp-cli, %USERPROFILE%\.idmp-cli\config.json, and %USERPROFILE%\.idmp-cli\sessions.json.
IDMP_CLI_SESSION_STORAGE=auto does not always mean keyring. On macOS and Windows it usually resolves to the system keychain. On Linux it uses keyring only when the current session has a working D-Bus session bus; otherwise it falls back to file. To confirm the effective backend, run idmp-cli auth status or idmp-cli doctor --offline and check session_storage_mode and session_storage_backend in the output.
If multiple agents, parallel CI jobs, or multiple terminals may run local state changing commands such as config init, auth login, or profile add/remove/use at the same time, do not share the same IDMP_CLI_CONFIG_DIR. A separate config directory per runtime unit is the safer pattern.
For quick multi-environment switching, combine profile use <name>, profile list, and the global --profile <name> flag.
15.4.10 Security Guidance
idmp-cli often runs with write access in automation and agent workflows, so its operating model should be treated as a security boundary rather than a convenience wrapper.
15.4.10.1 Protect Secret Input and Storage
Use the following defaults for sensitive data:
- Prefer
--api-key-stdinor environment variables over inline secret flags on the command line. - Do not place real credentials in scripts, shared shell history, screenshots, or documentation examples.
- When the environment supports it, set
IDMP_CLI_SESSION_STORAGE=autoorIDMP_CLI_SESSION_STORAGE=keyringso session tokens can be stored in the system keychain instead of relying only on local files. - Enable
--debug-httponly for short-lived troubleshooting, and avoid shipping that output into shared or long-retention logs.
15.4.10.2 Separate Environments and Permission Boundaries
Treat environment isolation as part of the CLI setup:
- Keep separate profiles for
default,staging,prod, and any other operational boundary. - In scripts and CI, pass
--profile <name>explicitly instead of relying on whichever profile is currently active. - Use API keys issued by least-privilege accounts in production and avoid giving broad write access to general-purpose agents.
- In CI or multi-user systems, use
IDMP_CLI_CONFIG_DIRto redirect config and session data into an isolated directory.
15.4.10.3 Preview Changes Before Execution
For any non-readonly operation, keep the following sequence:
- Run
idmp-cli schema <service.resource.method>first to inspect the expected parameters and request body. - Run the command with
--dry-runto preview the request shape. - Add
--ack-riskonly after the target object, environment, and payload are confirmed. - Add
--request-id <id>when the operation may need audit or backend correlation.
15.4.10.4 Understand Environment Variable Precedence
When both saved profiles and environment variables are present, pay attention to these overrides:
IDMP_BASE_URLoverrides the server URL stored in the profile.IDMP_API_KEYoverrides the saved local session.
Check these values first during troubleshooting, or the CLI may talk to a different environment than the current profile suggests.
15.4.11 Frequently Asked Questions
15.4.11.1 idmp-cli: command not found after installation
Check these 2 points first:
- Whether the global npm bin directory is already on
PATH. - Whether the terminal session has been reopened after
npm install -g.
15.4.11.2 The Web UI can log in, but the CLI cannot
Use this troubleshooting sequence:
- Run
idmp-cli config initagain and confirm the--servervalue is correct. - Confirm that the current API key is still valid.
- Run
idmp-cli auth check --remoteso the server verifies the current credential directly.
15.4.11.3 What if HTTPS uses a self-signed certificate?
idmp-cli follows the operating system trust store and does not automatically ignore untrusted self-signed certificates. In practice:
- If the self-signed certificate, or its issuing CA, is already trusted by the current machine, the CLI can use HTTPS normally.
- If the trust chain has not been imported yet, the CLI will fail during TLS verification.
- The CLI does not currently provide a
--insecure-style flag to skip certificate verification. - If you only need temporary connectivity troubleshooting, switch to
http://<IDMP_HOST>:6042only inside a trusted, isolated network and avoid sending sensitive credentials over HTTP; then move back to HTTPS after the issue is resolved.
15.4.11.4 The correct command path is unknown
Use this order every time:
idmp-cli schema search <keyword>idmp-cli schema <service.resource.method>- Then run the generated command or raw
apicall
This workflow is more stable than guessing the path and is also much easier to automate.
15.4.11.5 The agent keeps guessing the wrong command
The usual fixes are:
- For Claude Code, install only
idmp-pluginand do not duplicate the same skills. - For other agents, install
taosdata/agent-skillsfirst, and for offline installs pass--target-direxplicitly or copyassets/skills/*manually. - Instruct the agent to follow the sequence “
schema searchfirst,schemasecond, real command last”.
