8.7 Anomaly Detection
Anomaly detection requires the TDgpt module to be installed alongside IDMP. It does not require an LLM connection.
Anomaly detection in IDMP is powered by TDgpt, TDengine's built-in time-series AI engine. It is available as one of the eight trigger types when creating a real-time analysis. Unlike threshold-based triggers where you must define explicit boundary conditions, the Anomaly Detection trigger identifies unusual behavior automatically — you select the target attribute and the algorithm; TDgpt determines when anomalies begin and end.
8.7.1 How It Works
When an RT analysis is configured with the Anomaly Detection trigger, TDgpt continuously monitors the selected attribute's time-series data. It applies the chosen algorithm to model the expected behavior of the signal and flags periods where the observed values deviate significantly from that model. The RT analysis fires when an anomaly window is detected, and the event it generates captures the anomaly start and end times.
Because detection is model-based rather than rule-based, TDgpt can identify complex patterns — gradual drift, sudden spikes, seasonal deviations — that fixed thresholds would miss or falsely trigger on.
8.7.2 Configuring an Anomaly Detection Analysis
To create an anomaly detection analysis:
- Navigate to the element's RT analysis tab and click + to create a new RT analysis.
- In the Trigger section, select Anomaly Detection as the trigger type.
- Configure the Anomaly Detection trigger fields:
| Field | Description |
| Attribute | The element attribute to monitor for anomalies |
| Algorithm | The anomaly detection algorithm to apply (see below) |
| Window | The time window over which the algorithm evaluates each data segment |
- Complete the Calculation and Event sections as with any other analysis type.
- Click Save.
8.7.3 Supported Algorithms
TDgpt includes multiple anomaly detection algorithms backed by different ML frameworks:
| Algorithm | Framework | Characteristics |
| IQR | Statistical | Interquartile range — simple, fast, works well for univariate signals with clear outliers |
| LOF | scikit-learn | Local Outlier Factor — density-based, effective for detecting point anomalies |
| Isolation Forest | scikit-learn | Tree-based, robust to high-dimensional data and varying anomaly density |
| LSTM-AD | PyTorch | LSTM-based sequence model — captures temporal dependencies, suitable for seasonal or periodic signals |
| TDtsfm | TDengine | TDengine's own time-series foundation model, pre-trained on industrial time-series data |
The appropriate algorithm depends on the nature of the signal and the type of anomaly you expect. For most industrial sensor streams, IQR or Isolation Forest provide a good starting point.
8.7.4 Output
When TDgpt detects an anomaly window, the RT analysis fires and (if event generation is enabled) creates an event capturing the anomaly period. The start and end timestamps of the anomaly window are stored as event attributes.
For the full trigger configuration reference, see Trigger Types.
